psghosh
Nov 28, 2015Follower
EX6200 not enabling AES on WPA2-only option
I have an EX6200 acting as an AP with the most recent firmware( V1.0.3.68_1.1.104), and when I select the WPA2-PSK option for both bands, I noticed on both my laptop and WiFi survey device that TKIP ...
darsovit
Dec 28, 2015Aspirant
I'm having the same issue with my EX6200. All devices indicate that the encryption is WPA2-PSK-TKIP and not WPA2-PSK-AES as selected on the config screen.
This is with the latest firmware: V1.0.3.68_1.1.104
darsovit
Also, there is no option on security to set it to "None".
It's either "WPA2-PSK [AES]" or "WPA-PSK [TKIP] + WPA2-PSK [AES]". I've tried setting it to the latter and a message pops up about only supporting G and not N with those settings. When I've set it to the latter I do see that the mode reported in Wifi Analyzer (on android phone) is WPA-PSK-CCMP and WPA2-PSK-CCMP+TKIP, but when I put it back to WPA2-PSK [AES], it goes back to WPA2-PSK-TKIP (not CCMP).
