Jshoe
Oct 31, 2021Tutor
Ex6200 vs Eax20- Do they actually work differently?
I've had an EX6200 for years with a separate SSID for my network. Im going to switch that to the same SSID of the network. Then I can't easily switch between the the extender and the router. How does ...
Oct 31, 2021Guru - Experienced User
The EAX20 doesnt control the roaming.
Newer devices all have their own roaming protocol built in to where they should roaming to the stronger AP based on the details the AP sends to it. .
Not always stronger based on certain criteria but thats the basics of it.
so the EAX20 uses the same ssid but has the smart roaming spec built into it. so when a device queries it, it can respond to let the phone/tablet know its details so the phone/tablet can choose which network to content to.
That's a very very broke down way of explaining it.
If you want to get more into details, feel free to read here:
https://www.smallnetbuilder.com/wireless/wireless-features/33195-wi-fi-roaming-secrets-revealed
- JshoeOct 31, 2021TutorSo it doesn't do anything different and I have no gain by buying it for mesh networking? In mesh networks I have setup in the past the device hops from AP to AP no issue. This is on an 802.11AC network using the same devices. With my EX6200 my devices stay connected to said EX6200 even if the router has a stronger signal. How is the EAX20 going to fix this for me?
- plemansOct 31, 2021Guru - Experienced User
Didn't necessarily say the EAX20 would fix that.
The problem is both the router and the device you're using.
If the router doesn't have the proper roaming protocols, the device won't switch until the signal is quite obviously different/unusable.
If the device itself doesn't have the roaming protocols, then you're in the same situation.
Mesh networks are great but they aren't quite as efficient when its using pieced together setups like adding extenders.
If you're truly wanting to go mesh, look into the orbi or MK nighthawk setups where the whole system works together
- JshoeOct 31, 2021TutorWell what's the protocol? Netgear says it solves this issue with Easy Mesh Extenders. I want the hybrid solution that Netgear says will work a certain way. It's simple. I want what the company says they offer. ASUS AImesh works. Do I need to change brands. Maybe someone who works at Netgear can chime in to explain. Thanks
