Rsusca
Dec 04, 2019Tutor
EX6200 will not set up as access point
My EX6200 worked as an access point for years. I had to change its location and change the SSID. We I change the locatio, I also did a factory reset. Since them, I cannot access the web GUI to set it ...
- Dec 05, 2019I updated the firmware and I successfully set it up as an access point!
I feel like an idiot because I knew it had to be something simple that I was missing.
I appreciate your assistance.
Rsusca
Dec 05, 2019Tutor
Dec 05, 2019Guru - Experienced User
glad to hear you got it working!
If you mark the correct answer as solved, it'll help the next person with this issue. :)
