Jindidog
Dec 21, 2015Follower
EX6200 Wireless Extender connection options
I am considering a range extender for home - an EX6200 I have some questions : 1. Can the extender be connected to the router via an ethernet cable rather than wirelessly so it can be place furthe...
Babylon5
Dec 22, 2015NETGEAR Employee Retired
I’m pretty sure that the extender can connect to the router via an ethernet cable but can’t currently double check this.
The actions of client devices when moving around the house are set at the client devices themselves. Typically there will be a setting in the devices Advanced Properties called something like ‘Roaming Aggressiveness’ which will change how easily the device changes from one AP to another, there are plenty of Internet pages describing that function if you have a search.
