Keith7
Aug 18, 2015Aspirant
EX6200 Wireless Extender
Hope someone can help with this simple I think question. I use a BT Home Hub 5 router, and am already using an EX6200 as a wireless extender and it works just fine. My question is can I buy another o...
- Aug 26, 2015
The EX6200 is a universal extender; it can work with a variety of base stations including those from other manufacturers. There should be no reliance on any particular features of the base station and the EX6200 should effectively appear as a client device to the base station. You should therefore be able to associate more than one extender with the same base station; I have done this in the past with an EX6200 and an EX7000 without any issues.
I think that’s what you are asking in your post 1, and you are not suggesting base station to EX6200 to EX6200 i.e. daisy-chained? That would result in very poor throughput at the most distant client devices.
netwrks
Aug 19, 2015Master
I think in theory it can be done. There are a couple of other similar posts around, but one thing will be certain, throughput on your network will be abysmal..
Keith7
Aug 20, 2015Aspirant
Thanks very much for your reply, it certainly sounds not a good idea.
Keith
- Keith7Aug 26, 2015Aspirant
Whilst I am very grateful for your reply still do not have an answer to my question and want to know the answer. I am now being asked to accept a solution yet dont have an answer what do I do next?
Kind regards
Keith
- Babylon5Aug 26, 2015NETGEAR Employee Retired
Thank you so much.
Kind regards
Keith
