Kistonewa's avatar
Kistonewa
EX6200 won't connect to router. No "connect to existing network" option
I have an EX6200 that has worked fine in past. Was working but I needed to change name of SSID on my router. After I did this, it will not find this SSID or the SSID of another router I have. Both SSIDs are seen by my pc & 2 android phones. Did a factory reset. Still can't find any SSID.  I went to do a manual setup as outlined in the manual, however, "connect to existing network" option does not show up. I have all the other options the manual shows under that section of settings.  Is there an option somewhere else in setup that needs to be changed in order for me to have option of connecting to an existing network.? I am wanting to use as an access point for a printer. Do not need extender function.
  • plemans's avatar
    I guess I'm a little confused. If you're setting it up in access point mode, it doesn't connect to an existing network. It should be harwired into that network via ethernet. So it won't go through those settings in access point mode.
    • Kistonewa's avatar
      Kistonewa
      Thank you for clarification. Obviously don't know what I am doing with part of this. Last time I set it up was several years ago. Had been using to connect a couple devices to internet that don't have wifi capability. I thought it could could access mode wirelessly.
      • plemans's avatar
        There's a support site with access to manuals, firmware, install guides, etc.
        Go to https://www.netgear.com/support/
        Type in your model number and from there it'll take you to the above.
        Its a great resource to start with.
