Foxprints
Nov 06, 2021Aspirant
EX6200v2 cannot disable wifi completely
Why is it that I can't disable the wifi whenever I'm connected via fastlane to the 5 GHz network? pics: https://imgur.com/a/CNJYQL3 As you can clearly see, I have fully disabled the wifi rad...
Nov 06, 2021Guru - Experienced User
A stupid question. That firmware was released in september.
did you every try a factory reset with a reinstall?
sometimes old settings can cause issues.
