lkitsos's avatar
lkitsos
EX6200v2 constant disconnects after firmware 1.0.1.64
Hi all,
EX6200v2 use it as access point.
After upgrade to firmware 1.0.1.64 i get constant disconnects from wireless
Tested with iphone x samsungs s8 and laptops drop are happening every 5 to 10 minutes.
Anyone else has the same issue?
Any document for rolling back the firmware to last version that worked great.
Thank you
  • Hi lkitsos,
                       You can use the below link for downgrading firmware. Did you tried modifying wireless channel regarding this issue? Is it happening on both 2.4 and 5GHz bands? Did you performed a reset and reconfigured it back as AP after firmware upgrade?
  • Sorry for taking so long to reply.
    After a lot of upgrades and downgrades the most stable firmware is the
    • Firmware Version: V1.0.1.40
    Dont have drops and the are not disconnects from the mobile devices and laptops and tablets.
      • sethk's avatar
        sethk
        Just as an additional datapoint, I've been having this issue as well, but it started with the firmware included with the device, which I believe was V1.0.1.50, and it persisted after upgrading to V1.0.1.64. I'm currently testing V1.0.1.40.
