BacklashSamurai
Mar 26, 2019Aspirant
Ex6200v2 Wifi Extender fails to connect after setup
Recently had Spectrum upgrade wireless router so I have to reinstall my wifi extender. Im at my wits end with this one. The online setup says im finished and connected and led lights for both channels...
Mar 27, 2019Guru - Experienced User
Can you set up the EX at distance of about 10 feet away, then after it reboots. Power it off and place at it's remote location. Then see what happens. 1" is too close.
- BacklashSamuraiMar 27, 2019AspirantSame problem, the channels are set to auto on my router. Im wondering if it just boils down to a compatibility issue. Any other suggestions?
