jordijuve
Jul 22, 2020Follower
EX6250 (AC1750) el led de encendido parpadea indefinidamente y no es posible conectar
Hola,
He adquirido hace unos días otro extensor del mismo modelo, pero este al enchufarlo se queda el led del encendido se queda parpadeando indefinidamente. No hay forma de realizar la conexión con el extensor.
1 Reply
it sounds like you have a firmware issue. You might be able to recover via tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
If those don't work and you just bought it, I'd exchange it
