randycamp
Mar 19, 2020Tutor
EX6250 setup with Installation Assistant won't connect
I am having an issue in the last step of setting up a EX6250 using Installation Assistant. I get to the point of connecting to the extended wifi, but cannot connect. The Client Link LED is on during t...
- Mar 20, 2020
I would start with setting it up with wpa2. otherwise you'll want to change it later. might as well do it right from the start.
After that, try and set it up using the installation wizard
Mar 20, 2020Guru - Experienced User
why are you using wep security? switch to wpa2. its more secure.
what router are you connecting to?
i usually don't recommend setup via wps button but I'd try it in your case. I'd also switch your router's security to a more secure method.
- randycampMar 20, 2020Tutor
I can switch to WPA2, but would prefer to have one variable in this equation. Do you think WEP is a casue of the issue?
My router is a Actiontec MI424-WR, rev C. It does not have a WPS option.
- plemansMar 20, 2020Guru - Experienced User
