randycamp's avatar
Mar 19, 2020
EX6250 setup with Installation Assistant won't connect
I am having an issue in the last step of setting up a EX6250 using Installation Assistant. I get to the point of connecting to the extended wifi, but cannot connect. The Client Link LED is on during t...
  • plemans's avatar
    Mar 20, 2020
    I would start with setting it up with wpa2. otherwise you'll want to change it later. might as well do it right from the start.
    After that, try and set it up using the installation wizard
