randycamp
Mar 19, 2020Tutor
EX6250 setup with Installation Assistant won't connect
I am having an issue in the last step of setting up a EX6250 using Installation Assistant. I get to the point of connecting to the extended wifi, but cannot connect. The Client Link LED is on during t...
- Mar 20, 2020
I would start with setting it up with wpa2. otherwise you'll want to change it later. might as well do it right from the start.
After that, try and set it up using the installation wizard
randycamp
Mar 20, 2020Tutor
I can switch to WPA2, but would prefer to have one variable in this equation. Do you think WEP is a casue of the issue?
My router is a Actiontec MI424-WR, rev C. It does not have a WPS option.
Mar 20, 2020Guru - Experienced User
- randycampMar 20, 2020Tutor
plemans Thanks for the advice! Once I switched to WPA2 and ran the Installation Assistant, the same as I had done before, the setup worked as expected. Any idea why WEP would not work?
- plemansMar 21, 2020Guru - Experienced User
not sure why it wouldn't work with wep as it should but i'm happy it forced the switch. wep isn't secure
