Nov 14, 2021Follower
Ex6250
Bought this used at garage sale. Trying to set it up but cannot. It is registered to previous owner. How can I use this or get it unregistered so I can register and use it
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you. - plemansGuru - Experienced User
It doesn't need to be registered to be used.
I'd start with a factory reset. Push and hold reset for 7-15 seconds while its powered on.
then follow the install guide.
