omoeller
Jan 23, 2017Guide
EX6400 FW - any update?
Still trying to get my EX6400 with FW.44 somewhat to decntly work - any news about if/when to expect? Just to recap SSID's between 2.4. & 5 Ghz cannot be the same, does not support DFS channels, onl...
- Jan 30, 2017
Just returned the product to AAMAZON as it constantly looses connection on the 5Ghz under full signal - really disappointing.
DarrenM
Jan 25, 2017Sr. NETGEAR Moderator
Hello omoeller
Are you having issues after you went to the newest firmware?
DarrenM
omoeller
Jan 26, 2017Guide
Hi Darren - like I stated in my post I am on the latest FW:
SSID's between 2.4. & 5 Ghz cannot be the same, does not support DFS channels, only suppoers lower channels 36-40-44-48.
Responsiveness to web or app a pain in the rear.
I managed to address some while tricking the web interface - e.g. changing region during config. But overall there is ample room for improvement - including simple things like the option to turn off the LED's - something that the cheapest repeaters can handle!!
Thanks and Regards,
Oliver
