j3schwartz
Oct 31, 2019Aspirant
EX6400 lost connection with Orbi RBR50
Systems that connect to both the RBR50 and the EX6400 are Mac systems running the latest software updates. Xerox printers running the latest firware. Netgear EX6400/AC1900 Hardware version: EX64...
Christian_R
Nov 05, 2019NETGEAR Employee Retired
Hello j3schwartz,
Thanks for taking the time to post a detailed description of your issue and troubleshooting steps you've already taken. I'd like for our support team to get in contact with you for further investigation. If you're interested, please send me a message with your contact info and serial number(s).
Thanks,
Christian
- j3schwartzNov 06, 2019Aspirant
Christian_R,
I PM'ed you my contact info. Problem still exists; unable to connect the EX6400 to my RBR50 where once I was able to do so without issue. If I have time I'll run a trace using Wireshark and see if that can provide more info.
--j3schwartz
- j3schwartzNov 18, 2019Aspirant
Based on an indepth discussion with Netgear support, it has been determined that I may have a faulty EX6400. I've been sent a replacement and I'll update the discussion when the new unit has been installed and tested.
