SAG1
Mar 03, 2022Tutor
EX6400 setup password error?
I have two networks (Main and Guest). I've used my extender for quite a while, extending the Guest network but decided to reset the extender and have it extend the Main network. After a reset the ex...
Mar 03, 2022Guru - Experienced User
are you using any special characters or spaces?
Avoid them if you do.
SAG1
Mar 03, 2022Tutor
Well that sucks. Yes I've included symbols.
I have over 30 wifi devices that are programed to my Main network.
I'm not about to change the Main network's password just so NetGear Extender will like it.
Too bad.
Thanks for the help.
