tyty8991
Jul 31, 2020Aspirant
EX6400v2 Booting
My extender will not boot up past: Amber, Blue, Blue, Amber; then power is Amber and WPS is green. Will not change, will not reset, will not let me connect local or ethernet.. What can I do? Expert t...
Aug 01, 2020Guru - Experienced User
just listing off colors doesn't help.
Which led is which color? Be specific
How long have you owned it? netgear has 90 days of free support from date of purchase and most places have a 1 year (2 in some regions) warranty if it was purchased new.
Also, how did you try to contact support? many google for a number and get scam/con sites.
to contact support you click "mynetgear" at the top. register an account and then the device. From there you can contact support.
When you're resetting, are you pushing and holding reset for 7-15 seconds while powered on? What happens when you do this?
- tyty8991Aug 01, 2020Aspirant
Router Link LED: Amber
Router Arrow LED: Blue
Client Arrow LED: Blue
Client Link LED: Amber
Power LED: Amber
WPS LED: Green
My one year warranty expired in April. Device is registered.
I spoke with Netgear Support and they instructed me to power off all devices for 2-5 minutes then hold reset on extender for 90 seconds. I have done this repeatedly with no success. Same LED's as listed above all come on immediately after powering on and do not change or flash when attempting to reset.
Any and all help is appreciated!
- plemansAug 01, 2020Guru - Experienced UserYou might try recovering it via tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- tyty8991Aug 01, 2020Aspirant
Unfortunately, I am using a MacBook. I appreciate the tips. Thanks
