notter59
Feb 28, 2021Aspirant
EX6400v2 Extender IP Does not Appear in Ubee Router DHCP Client list
My friends replaced an old WN3000RP extender with an EX6400v2. It has the latest 134 firmware in it. It has not worked well so far. The typical problem is after awhile you can still connect to it ...
Feb 28, 2021Guru - Experienced User
Was it setup using wps or using the installation assistant?
notter59
For some reason, WPS would not work. I also wanted to be able to easily differentiate between connections so I didn't use One Wifi Name. Not a fan of the integrated wifi in the Ubee modem. They had problems with their Nighhawk 1750 so they ended up with the Ubee wifi when the Spectrum tech showed up and replaced their old modem that wasn't capable of higher speeds.
- plemansFeb 28, 2021Guru - Experienced User
have you assigned a static ip address to the extender in the ubee interface?
