faded206
Mar 01, 2022Aspirant
EX6400V2 extender wont broadcast its network
I am having no luck with 4month old extender it was a set up as a accsess point I believe it had been hacked I did a hard reset on the ext made a new network with tuffer password then it stoped worki...
- Mar 01, 2022
Your power light is blinking?
Usually indicates a corrupt firmware.If its within warranty, you can contact support about an rma.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.Or you can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Mar 01, 2022Guru - Experienced User
faded206
Mar 02, 2022Aspirant
So the strangest thing ever, i tried to do tftp transfer the firmware snd was unsuccessful i can to work on it today and it started working suddenly and is acting as if it reset but now the night hawk app wont connect I'm working on it now
Thankyou for your reply it did not seem to work last night but now it seems it did i appreciate the help
