pquebodeaux
Feb 24, 2023Guide
EX6400v3 extender
I can't connect my extender to Channel 2.4 GHz. I've had it for 2-3 years and started having problems with it in the last few months. I have done a factory reset several times and reconnect to severa...
pquebodeaux
Feb 28, 2023Guide
I have an ATT provided modem/router that they installed with my new fiber optic service. The software version of the extender is V1.0.3.32. I have used the WPS setup and its worked in the past. Neither channels stay connected. There are 4 lights and only the first 3 stay lit. Occasionally, all 4 are lit up. Number 1 is power, 2 is WPS, 3 is router link, and 4 is client link. It is 4 that stays off. Hope this helps, I am not very savvy at these electronic devices.
Feb 28, 2023Guru - Experienced User
When setup with WPS, the EX6400 sets up in mesh mode as its a mesh extender. What that means is it uses the same ssid/password as the main router. And devices roam between it (EX6400) and the router as needed based on their own roaming protocol. Thats why your led 4 (device) light only comes on sometimes. That'd be when devices choose to roam to it.
You can disable that and set it with its own ssid if you'd prefer.
- pquebodeauxMar 01, 2023Guide
Well, that may help. Thanks
