DaveInFL
Jun 16, 2021Aspirant
EX700 wifi dropping signal
Hi there, I have 3 Netgear devices in my home. One is the C7100V that I recently put in place to replace my Comcast Modem. As far as I can tell this is working fine and WiFi is working fine on ...
manisrah4
1.Check the power system. Maybe it`s just problem with electicity.
2.Driver versions? Did you update your EX700?
- DaveInFLJun 16, 2021Aspirant
The power system is not an issue as there are multiple devices connected to the same power source as both EX700's.
The firmware version on both is the same: V1.0.1.94_1.0.172
- plemansJun 16, 2021Guru - Experienced User
A couple things.
1. Netgear doesn't have an EX700. based off firmware and your listing, you must mean EX7000
2. When the extenders are hardwired into the router and are setup as an extender, it can cause issues/not work properly. If you're hardwiring them into the router, they need to be in AP mode. (It'd also be the fastest mode)
2. If they're in AP mode, they don't function as a mesh device with their smart roaming. They need to be on separate wireless channels to prevent interference. You can use the same SSID (I wouldn't) like with a mesh network but it won't roam like a mesh network as devices will tend to stay connected until the signal deteriorates to the point of unusable or the device disconnects, reconnects.
3. Daisy chaining extenders (over wireless) also can be an issue. Not a problem if you're hardwiring them in but if you're using them wireless and in mesh mode, they can end up connected to each other and cause issues. its why I recommend people move to an actual mesh system like Netgear Orbi or MK nighthawk when they're needing more than 1 extender.
So try this.
Hardwire in the access points. Use a different ssid's from the router and make sure you've spread out the wireless channels you're using to prevent interference. Try that.
Appreciate the reply, however, I don't want to have separate SSID's as that is what I had before and that was hard for my wife to grasp that the house has multiple networks and depending upon where she is in the house she needs to ensure she is on the right network, if the phone/ipad doesn't automatically switch over.
That is why I went with the Mesh Network, so it would be transparent.
You stated that is the extender is hardwired to the router that causes the mesh network not to work, why? I am curious. There doesn't seem to be anything (that I could find) on the Netgear website that indicates not to do this. I'm not sure why that should be an issue too, hardwire and WiFi are separate.
So, I really don't want to go back to the AC mode and different SSID's. Hoping someone else can shed some light.
Also, yes, EX7000, sorry, too many zeros for my eyes.
