davidtkhayes
Aug 18, 2019Aspirant
EX7000 / AC1900 Extender cannot connect using Hotel Wifi
I am traveling for business and trying to set up a Range Extender to use in my room with the Hotel Wifi. The hotel wifi normally just brings you to a page on the laptop to say "Connect Now" and then...
davidtkhayes
Aug 22, 2019Aspirant
- Hardware Version: EX7000
- Firmware Version: V1.0.1.80_1.0.144
2.4Ghz Link Rate LED - Green
5Ghz light is out (I did not configure the 5G part in setup but have tried with it on and off)
Device to Extender LED is Green
LAN LED 2 is Green (Plugged into my computer)
USB LEDs are off, nothing plugged into them
davidtkhayes
Aug 26, 2019Aspirant
I worked with Netgear telephone support (thanks) for the past few days and it appears that this extender simply does not qwork with the hotel Wifi. The Hotel and other businesses use something called captive portal, in essence requiring further prompting to connect, usually within a web browser and that is not supported by the Netgear home products.
I returned the unit to the store, searching for a product that does work, no luck yet.
