bllfr0g
Oct 02, 2018Guide
EX7000 + Firmware Version 1.0.1.78 == crash
Echoing what others on the forum have said, I have an EX7000, and after upgrading to firmware Version 1.0.1.78, it appears to work for a few minutes but then seems to crash/reboot. This behavior is ...
Troubleo
Oct 22, 2018Initiate
Sadly I have the same issue, and even worse. I rolled back to 1.0.0.66 but the funtion is still not sable. My mobile devices cannot connect to its extend wifi network. The device also died randomly in minutes. I have also tried the initial verion 1.0.0.30 and some other versions. Almost the same problems.
schumaku
Oct 23, 2018Guru - Experienced User
Can't help much - a factory reset and a reconfig from scratch might be required to revert to previous firmware.
