bllfr0g
Oct 02, 2018Guide
EX7000 + Firmware Version 1.0.1.78 == crash
Echoing what others on the forum have said, I have an EX7000, and after upgrading to firmware Version 1.0.1.78, it appears to work for a few minutes but then seems to crash/reboot. This behavior is ...
Troubleo
Oct 22, 2018Initiate
Sadly I have the same issue, and even worse. I rolled back to 1.0.0.66 but the funtion is still not sable. My mobile devices cannot connect to its extend wifi network. The device also died randomly in minutes. I have also tried the initial verion 1.0.0.30 and some other versions. Almost the same problems.
Troubleo
Oct 23, 2018Initiate
By the way FYI, for your rolling back option, I am running on V1.0.0.50_1.0.102 which is quite stable.
- pkincyDec 18, 2018Aspirant
How do you access the older firmware?????
- schumakuDec 18, 2018Guru - Experienced User
https://www.netgear.com/support/product/EX7000.aspx#download -> View Previous Versions
Thank you. Working on trying .66
- sgreene978Jan 30, 2019Aspirant
BTW...how do I roll back to a previous version of the firmware?
Thanks!
- Gordon62Jan 30, 2019Aspirant
Answer was provided earlier in this thread.
