bllfr0g
Oct 02, 2018Guide
EX7000 + Firmware Version 1.0.1.78 == crash
Echoing what others on the forum have said, I have an EX7000, and after upgrading to firmware Version 1.0.1.78, it appears to work for a few minutes but then seems to crash/reboot. This behavior is ...
Troubleo
Oct 23, 2018Initiate
By the way FYI, for your rolling back option, I am running on V1.0.0.50_1.0.102 which is quite stable.
pkincy
Dec 18, 2018Aspirant
How do you access the older firmware?????
- schumakuDec 18, 2018Guru - Experienced User
https://www.netgear.com/support/product/EX7000.aspx#download -> View Previous Versions
- pkincyDec 18, 2018Aspirant
Thank you. Working on trying .66
The link and Firmware 66 edition apparently works. I am now connected. But you need to be vigilant as I simply logged back in to Mywifiext.net and the first thing it did was tell me there is a "great update" available. Do you want to try it?? Well, I expect that great update is the broken firmware. It is annoying that Netgear has not taken it down.
