bllfr0g
Oct 02, 2018Guide
EX7000 + Firmware Version 1.0.1.78 == crash
Echoing what others on the forum have said, I have an EX7000, and after upgrading to firmware Version 1.0.1.78, it appears to work for a few minutes but then seems to crash/reboot. This behavior is ...
Dec 23, 2018Guru - Experienced User
Have you tried downgrading the firmware to 1.0.0.66
fadsarmy
Jan 12, 2019Aspirant
Is this ever going to get fixed?
- Piwi38Jan 30, 2019Aspirant
Hello,
I tried again today t update the firmware and the problem isn't fixed. Almost sure that the problem of connection or stability can come from the fact after the update the virtual MAC adress of 2.4 and 5Gb are strictly the same.
As they are identical, the router isn't able to adress correctly the right network and connections are impossible or difficult.
I opened a ticket during my guarantee and never been contacted about it from technical service. I saw that other peolple tried without success. A large part of us signaled, highlighted the issue but nothing change since several months.
Netgear replaced my EX6200 bought in July because they have a firmware issue They provides a EX7000 and now they reproduce the issue on it. I have some doubt about their capacities to solve but I'm sure they are able to duplicate the problem.
Several years I use their products but maybe it's timeto go away...
- bllfr0gFeb 03, 2019Guide
FWIW some folks from Netgear did contact me back in October after I first reported this. They seemed interested and said engineering was working on reproducing the issue. But... crickets since.
