browndonray
Mar 20, 2019Follower
EX7000 AC1900 Memory Leak
Our management system pings the EX7000 regularly and we have noted the response time gradually extends, getting very long after a couple of days. Restarting the router returns response times to norm...
Mar 20, 2019Guru - Experienced User
Other user are seeing problems with the latest FW.
I recommend you revert back to v66...
browndonray wrote:
Our management system pings the EX7000 regularly and we have noted the response time gradually extends, getting very long after a couple of days. Restarting the router returns response times to normal, but they continue to increase after that. Firmware version is 1.0.1.78. This sounds like a memory leak, but, are others having similar issues?
misops
Mar 20, 2019Tutor
When you updated the firmware did you perform a 30-30-30 reset? In the past when I would just update the firmware on my AC1900 I would have issues with performance. If I did a 30-30-30 (or nvram reset) then reconfigured the device after the firmware update it behaves much better.
- FURRYe38Mar 20, 2019Guru - Experienced User
Did this work for you on the v78 version of FW?
