Chriscmm
Apr 20, 2022Aspirant
EX7000 (AC1900 WiFi Range Extender) locks up couple times a week
For a few months I've been using the EX7000 (AC1900 WiFi Range Extender) connected to my C3700-100NAS, through both 2.5 and 5 GHz bands. A couple times each week, the network capability seems to lock...
Apr 20, 2022Guru - Experienced User
when it loses connectivity, does the router still work?
Is it just the extender that stops?
Are you able to access the extender if you hardwire into it?
Also, you might update the firmware on the extender,
- ChriscmmApr 20, 2022Aspirant
Yes
Yes
I never tried it. I reboot it.
Yes I saw there is an update. Thanks
