navsonline's avatar
navsonline
EX7000 Access Point Mode To Nighthawk X6 working at 100 mbps
Hello Everyone, I have a Nighthawk X6 R8000 router connected over Cat5e cable to a EX700|AC1900 extender. The cable from the router terminates on a Cat5e compatible patch panel and I am using another...
  • DexterJB's avatar
    Feb 26, 2020
    Hi navsonline, what is the firmware version of the router and the extender? Does the issue persist if you have the extender directly connected to the router and not through the patch? Have you tried using another port on the router or another cable? Do your other Gigabit capable wired devices get the expected throughput from the router (with white LED)?
    Dexter
