navsonline
Feb 19, 2020Aspirant
EX7000 Access Point Mode To Nighthawk X6 working at 100 mbps
Hello Everyone, I have a Nighthawk X6 R8000 router connected over Cat5e cable to a EX700|AC1900 extender. The cable from the router terminates on a Cat5e compatible patch panel and I am using another...
- Feb 26, 2020
Hi navsonline, what is the firmware version of the router and the extender? Does the issue persist if you have the extender directly connected to the router and not through the patch? Have you tried using another port on the router or another cable? Do your other Gigabit capable wired devices get the expected throughput from the router (with white LED)?
Dexter
DexterJB
Feb 26, 2020NETGEAR Moderator
Dexter
DexterJB
Feb 28, 2020NETGEAR Moderator
