skplastics
Aug 14, 2020Aspirant
EX7000 Cannot connect after Firmware Update
Hi, I received an email from Netgear this morning, advising to install to a new security firmware update. I logged into the extender, checked for a firmware update, and installed. I did not record ...
skplastics
Hi,
Thanks for the advice. No I am on a mac.
Both Both Link Rate LEDs are Amber, the Device to extender LED is flashing green and the Ethernet port I am using is green.
I will have a look at stuff you sent and let you know how I go. Thanks again.
Aug 14, 2020Guru - Experienced User
I would try the factory reset again. Push and hold it while powered on. The lights should flash/blink when held long enough.
then follow the reinstall guide
