Chrispanola
Sep 12, 2022Guide
EX7000 Completes Network Setup But No Internet Connection and Unable to Access
Hello, I've seen posts related to this, but all unresolved or dead threads. My AC1900 EX7000 extender connects to my home Xfinity Network Utilizing an TG4482A Arris Router (XB7-CM generation)...
Sep 12, 2022Guru - Experienced User
When you're setting it up with it hardwired, you'd be setting it up in access point mode. In access point mode, it needs to be hardwired in.
So if you don't plan on using that, don't run setup with it hardwired in.
If you're setting it up in extender mode, you'd use that installation assistant but try disabling the one wifi (mesh feature) so you can set it with its own ssid.
