Mcfr05ty
Apr 15, 2019Follower
EX7000 DHCP Not Working
So, I've had issues with DHCP not working with this extender since I got it over a year ago, a few months ago I rolled the firmware back to the initial release (1.0.0.30), and that seemed to fix the ...
Apr 16, 2019Guru - Experienced User
Mcfr05ty wrote:
So, I've had issues with DHCP not working with this extender since I got it over a year ago, a few months ago I rolled the firmware back to the initial release (1.0.0.30), and that seemed to fix the issue wholesale.
Night before last we had some pretty severe storms and the power went out for a second, since then the extender refuses to assign IP addresses via DHCP. Setting a Static IP on the device I wish to connect works.
My router is one of the Arris AT&T U-verse DSL gateway and router combo units. I have a linksys extender connected to that, and the EX7000 is connected to that. This setup DID WORK, and quite well, the issue is with the EX7000, as if I do not set a static IP I cannot even get into the extenders settings page via mywifiext.com. I am forced to use such a configuration as AT&T has deprecated it's DSL services and will not run new service to my home, on top of that, they do not offer any other services at my address, neither do any other ISP's. So I must extend from my grandfather's house, only ~100 feet away. The DSL modem and Linksys extender are there, the EX7000 is in the closest point in my home to the Linksys extender.
Here's a list of things I've tried to rectify the issue:
1: Restarting the extender ("Have you tried turning it off and back on again?")
2: Factory Resetting the extender
3: Updating the firmware to the latest release, then factory resetting
4: Re-downgrading the firmware to the initial release, then factory resetting
5: Setting a Static IP for the extender (Linksys DHCP is working, I can connect to it no problem, so this was pointless)
This is not the first time I've had issues with DHCP. It seems that most networking equipment I possess, at one point or another DHCP stops working. Went through several ATT modem/routers, some Netgear, some Arris, a D-Link wireless router, and now this Netgear extender. I'm wondering if it's an issue inherent to the design of DHCP hardware, or if most networking companies just cheap out on said hardware.
I get that you're trying to extend this via wireless. If you're only running 100ft you could bury either an underground rated ethernet cable or a underground rated coax cable (use moca adapter) to extend your distance. Probably $50-75 for the wire. For added protection you could put it in a conduit but it isn't necessary because it isn't high voltage. Buried a line around 100ft with it being a foot deep for a project I was doing. Its been running for 4 years without issue.
If you did this you could either put a router in AP mode or even just one of your extenders in AP mode and use it. Less latency and speed loose due to using multiple repeaters.
- nicknnAug 03, 2019Aspirant
Dude. It's an extender not a router. It doesn't have dhcp. How is your linksys extender connected to the main router. If its via Ethernet cable that would be good. I would give the access point created by Your linksys a different name to your main router. Your netgear extender would then extend this new wireless network. Use static ip addresses for all your devices on this network that fall in the dhcp range of the main router. Static ip for the extenders too.
