BobFord
Jan 09, 2017Aspirant
EX7000 Extender & ReadyCloud
I know it is possible to use ReadyCloud for my Nighthawk Router, but is it possible to define ReadyCloud (for external access) on the extender as well? TVMIA Bob
DarrenM
Jan 11, 2017Sr. NETGEAR Moderator
Hello Bobford
You should be able to use readycloud while connected to the extender since it is still on the same network.
DarrenM
BobFord
Jan 11, 2017Aspirant
Thanks Darren
When I'm connected to my home network then I see the extender happily and can access the drive attached. What I'd like to do is access the extender/drive attached remotely (as I can do with my NAS and router (which also has drives attached)
- DarrenMJan 11, 2017Sr. NETGEAR Moderator
Hello Bobford
Here is the list of supported routers for ready cloud access.
http://kb.netgear.com/27323/Which-NETGEAR-routers-support-ReadyCLOUD?cid=wmt_netgear_organic
DarrenM
