DickDuke
Oct 07, 2018Apprentice
EX7000 Extender as Mesh Network Access Point
After upgrading both router and extender to the latest firmware, I set about converting from a dual SID router + access point to a single SID Mesh network. I first set up the EX7000 in access point m...
- Nov 18, 2018
Just as an aside here... I eventually bought the Orbi RBK23 kit (router plus 2 satellites) so never did figure out the behind the scenes configuration. I'll add, that the reason I upgraded to the newer Orbi system, was that the EX7000 was never ideal as a solution. It seemed that I had to trade off simplicity for reliablity (ie use with a different SID) because no matter how I configured it, it never matched the performance of the Router by itself.
The RBK23 works like a charm. Thought there were occasional challenges getting everything to work the way I wanted.
gaidin43
Nov 12, 2018Initiate
I have the same question on this. I am using an r7000 nighthawk as an access point and the ex7000 as another access point behiend the same router. I can’t tell if either one is operating as a mesh or not on the same ssid
- DickDukeNov 18, 2018Apprentice
