DickDuke's avatar
DickDuke
Apprentice
Oct 07, 2018
EX7000 Extender as Mesh Network Access Point
After upgrading both router and extender to the latest firmware, I set about converting from a dual SID router + access point to a single SID Mesh network. I first set up the EX7000 in access point m...
  • DickDuke's avatar
    DickDuke
    Nov 18, 2018
    Just as an aside here... I eventually bought the Orbi RBK23 kit (router plus 2 satellites) so never did figure out the behind the scenes configuration. I'll add, that the reason I upgraded to the newer Orbi system, was that the EX7000 was never ideal as a solution. It seemed that I had to trade off simplicity for reliablity (ie use with a different SID) because no matter how I configured it, it never matched the performance of the Router by itself.
    The RBK23 works like a charm. Thought there were occasional challenges getting everything to work the way I wanted.
