Edembers
Mar 20, 2021Aspirant
EX7000 extender dropping wifi connections
I have a Starlink connection which was served by a Nighthawk R7000, which served 3x EX7000 extenders. All on the latest firmware and working perfectly, but would sometimes drop the wifi connection of...
michaelkenward
Mar 21, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Edembers
Mar 25, 2021Aspirant
Thanks for that.
I've now turned on FastLane and that seems to have fixed the problems, it connects instantly instead of a turning circle for ages. I also tried connecting a Ubiquiti AP to the extender and it refused to work (it got an IP address but couldn't connect a device) until I activated FastLane. So the problem appears to be whenever 2.4GHz and 5GHz is shared, and Unifi highlights it too.
I'm going to keep an eye on it.
