pkincy
Dec 18, 2018Aspirant
EX7000 Extender Setup Options
In setting up an EX7000 extender you have an option to allow separate SSIDs or use the same SSID. Which is the preferred and why?? If you connect to a device with an SSID-2ext name will it be able ...
Dec 21, 2018Guru - Experienced User
If you use a different network name in the extender, then you normally will need to manually switch networks in your mobile device as you move through the house. That can be inconvenient.
In most cases there isn't any advantage in using a different network name.
pkincy
Dec 26, 2018Aspirant
I likely did not phrase my Q properly. If Device 1 is connected to SSID and Device 2 is connected to SSID_ext2 are they on the same network. In other words can Device 1 and Device 2 share files and communicate across the network although they are using separate SSIDs.
