pkincy's avatar
pkincy
EX7000 Extender Setup Options
In setting up an EX7000 extender you have an option to allow separate SSIDs or use the same SSID.  Which is the preferred and why??  If you connect to a device with an SSID-2ext name will it be able ...
  • StephenB's avatar
    Dec 27, 2018
    pkincy wrote:
    In other words can Device 1 and Device 2 share files and communicate across the network although they are using separate SSIDs.
    Yes.
