s13t0ttz
May 31, 2022Aspirant
EX7000 extending network that has a proxy
Hello Everyone, I have an EX7000. I live in an apartment building. The provided WiFi uses a proxy. To describe, this is how I gain access to the internet. I find the SSID. I select it and...
May 31, 2022Guru - Experienced User
If there's a proxy, you don't need an extender. You need a router/extender that supports wisp mode. standard extenders like the ex7000 doesn't.
Most routers don't even have a wisp mode. A lot of travel routers support a wisp mode.
s13t0ttz
Jun 01, 2022Aspirant
Hello there!
Thanks for writing!
I got the extender because the wifi signal is weak where I live. So how do I solve that and the proxy issue?
What device would you recommend then?
Best,
Thor
- plemansJun 01, 2022Guru - Experienced User
Again, you need a device that supports wisp mode.
standard extenders done.
So look for either a router that supports wisp mode or a lot of travel routers do.
The only one from netgear that supports it is super old and not worth the $.
