FredK99's avatar
FredK99
Follower
Mar 19, 2019
EX7000 Firmware .78 Still Useless
I tried loading this 'update' some months ago and could not get my Ex7000 to link to the router.  I was forced then to drop back to .58 where I had been before.
This week, I got a message claiming that there were two new packages.  One for my Nighthawk R7800 router (I already had the touted firmware loaded) that was not really "newer;" and one for the Ex7000.  It was the same old .78 version that failed before and for some unknown reason I thought it might work with my newer Nighthawk router even though it failed with my old Linksys.  It did not; it was a connectivity disaster and nothing I tried/did made it any better!!
3 frustrating hours later, I had dropped back to .66 firmware, reset SSIDs and passphrases and everything worked again on 2.4 and 5 GHz bands. I should not have wasted time with it in the first place, but highly disappointed in Netgear pushing a firmware update that does not go seamlessly into my equipment.  I'll stay with .66 version unless they can assure me that a newer version is OK.
1 Reply
  • FURRYe38's avatar
    Your not alone:
    https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7000-Wifi-Range-Extender-Dropping-out-after-upgrade-latest/m-p/1723296/highlight/true#M29922
    Keep v66 loaded for now. NG seems to be aware of the problem.
