Resmithn's avatar
Sep 30, 2018
EX7000 Firmware Update - GUI Language File is invalid
After clicking Yes to update, message is "GUI Language File is invalid" and returns to status screen. Email was received from Netgear to install new update per security issues. Windows 10 environme...
  • schumaku's avatar
    Sep 30, 2018
    Updated an EX7000 from an earlier firmware to 1.0.1.78 using the "one click" method on the extender, the process worked out as expected.
    The language file is integrated with the single zip archive, resp. the chk firmware image. Must be an incomplete download. Get it manually from EX7000 downloads, unpack the ZIP archive, and use the manual firmware upload from the extender Web UI.
