pviljoen
Feb 13, 2018Follower
EX7000 Loosing its connection tot he internet
AC1900 Wifi extender
- Hardware Version: EX7000
- Firmware Version: V1.0.0.64_1.0.124
The extender is loosing its connection tot he internet if you connect via wifi. You can reboot it, its last for about 30 min and then no connection. Perfomace is noin existing.
Tried the following
reboot - good for about 20 to 30 min then performance is non existing
Reset and upgrade with latest fixes. good for about 20 min the performance is non existing.
The perfomance is so bad that it akes about 12 to 15 minutes just to connect to the extender - mywifiext.net. Once connected the systems does not recognise your own support website servers. Total crap.
If I connect via ethernet directly to the extender than performance is back to normal.
My opinion. You have taken an average tool and turned it into crap after the latest two fixes.
This has now gone on for two weeks and I have had to pay just over 10k in late penalties for my projects. TIME TO FIX THIS!!!~!
1 Reply
- asgardnerInitiate
I have the same problem. . . We are going to return it.
