F1Com
Jan 21, 2020Tutor
EX7000 most stable firmware?
In September, I updated the firmware to V1.0.1.80_1.0.144. It was a nightmare. Wi-fi kept disconnecting, Macs wouldn't get assigned an IP, etc. I downgraded 80 to 78 to 68, then finally to 56, where ...
MizzouGuy1970
May 28, 2020Aspirant
Just curious if you stayed on 56?
I've had nothing but trouble with this ex7000 and R7000. I finally turned off the ex7000 because it would drop out daily and I've to reboot it. Only 2.4 seems to be semi-stable with no extender.
These have been very bad purchased, ready to switch to another product.
F1Com
May 28, 2020Tutor
I did stay on 56.
Last year I had installed 1.0.1.80_1.0.144 and everything went to crap. Mac's couldn't automatically connect or even locate the AP, wifi kept disconnecting.
So I dropped all the way down to 1.0.0.42 because I didn't know where it started. Wifi worked, but on the Admin login screen it stated, "Your access point has no internet access" even though there was internet!
Installed 1.0.0.50, same error but everything else was okay.
Installed 1.0.0.68. Was okay.
Installed 1.0.0.78. Had same issue as .144 !
Installed 1.0.0.50.
Installed 1.0.0.56.
Didn't bother trying 68 again.
