F1Com
Jan 21, 2020Tutor
EX7000 most stable firmware?
In September, I updated the firmware to V1.0.1.80_1.0.144. It was a nightmare. Wi-fi kept disconnecting, Macs wouldn't get assigned an IP, etc. I downgraded 80 to 78 to 68, then finally to 56, where ...
MizzouGuy1970
May 28, 2020Aspirant
Just curious if you stayed on 56?
I've had nothing but trouble with this ex7000 and R7000. I finally turned off the ex7000 because it would drop out daily and I've to reboot it. Only 2.4 seems to be semi-stable with no extender.
These have been very bad purchased, ready to switch to another product.
May 29, 2020Guru - Experienced User
MizzouGuy1970 wrote:Just curious if you stayed on 56?
The R7000 isn't known for the best firmware. What version are you on for that? The stable version is 1.0.9.42 for the R7000. I'd try installing that version, factory reset the router, and then reinstalling it. Don't use a backup setup.
- F1ComMay 29, 2020Tutor
If you read my post, I did quite a bit of testing. I am currently running 56 and it has been very stable. I originally asked if anyone has experience with more current versions, but no one responded. I'm leaving good enough alone unless I hear from others.
- MizzouGuy1970May 29, 2020AspirantLast night I downgraded the r7000 to .42 followed by a factory reset. Downgraded the ex7000 to .56 followed by a factory reset.
Overall, 5ghz was worse. Kept connecting and reconnecting on all devices. 2.4 seemed stable still.
This morning I turned off the ex7000. Now both 2.4 and 5 are stable so far.
Setup, AP mode with mesh...using the same ssid on both the r7000 and ex7000. 2.4 and 5 separate ssids.
Any suggestions to get the ex7000 back on?
