vertering
Mar 05, 2021Tutor
EX7000 not assigning IP addresses
Hi, I've purchased the EX7000 recently to increase the WiFi coverage of my R7000 in my house. With a number of devices, notably my Nokia 8 phone, I don't properly connect to the WiFi network beca...
- Mar 05, 2021
you might try updating to the 1.0.11.116 for the R7000. Then try a factory reset and reinstall of the router. Its the backbone of the system.
Mar 05, 2021Guru - Experienced User
What modem/gateway do you have?
what firmware is on the R7000? (its not known to have the best)
When the Ex7000 is on/running, does it work if you hardwire a device into it?
