vertering
Mar 05, 2021Tutor
EX7000 not assigning IP addresses
Hi, I've purchased the EX7000 recently to increase the WiFi coverage of my R7000 in my house. With a number of devices, notably my Nokia 8 phone, I don't properly connect to the WiFi network beca...
- Mar 05, 2021
you might try updating to the 1.0.11.116 for the R7000. Then try a factory reset and reinstall of the router. Its the backbone of the system.
vertering
Mar 05, 2021Tutor
Hi,
I have an ISP provided router/modem, which I've let the ISP set in bridge mode, with behind my R7000 running is my main router, responsible for everything including DCHP.. The R7000 is running on firmware version V1.0.9.88_10.2.88.
The EX7000 is running on firware version V1.0.1.94_1.0.172.
Just disconnected from WiFi on my laptop and connected it with a cable to the extender, and I got an IP address and an internet connection. Pulled out the cable and connected again to the WiFi network, got an IP address but not internet connection.
- plemansMar 05, 2021Guru - Experienced User
