vertering
Mar 05, 2021Tutor
EX7000 not assigning IP addresses
Hi, I've purchased the EX7000 recently to increase the WiFi coverage of my R7000 in my house. With a number of devices, notably my Nokia 8 phone, I don't properly connect to the WiFi network beca...
- Mar 05, 2021
you might try updating to the 1.0.11.116 for the R7000. Then try a factory reset and reinstall of the router. Its the backbone of the system.
vertering
Mar 08, 2021Tutor
Thanks for the tips! I've updated my R7000 to the latest firmware, did a factory reset and reinstalled the router again. After this, I did a factory reset on the EX7000 (just to be sure) and reinstalled it too. I sat down next to the EX7000 and plugged in a cable to see whether I could get an IP address and an internet connection, which was the case. Then I check the WiFi (pulled out the cable first) and with a WiFi connection I also got an IP address and internet connection. So it seems to be working, I'll will test it a number of times the next couple of days to be sure.
Mar 08, 2021Guru - Experienced User
Glad its up and working!
