vertering
Mar 05, 2021Tutor
EX7000 not assigning IP addresses
Hi, I've purchased the EX7000 recently to increase the WiFi coverage of my R7000 in my house. With a number of devices, notably my Nokia 8 phone, I don't properly connect to the WiFi network beca...
- Mar 05, 2021
you might try updating to the 1.0.11.116 for the R7000. Then try a factory reset and reinstall of the router. Its the backbone of the system.
vertering
Mar 11, 2021Tutor
Yesterday I had Smart Connect enabled again, which resulted in issues again, as I played a shooter online and was seriously hampered by lag. Disabled Smart Connect again, and everything went smooth again. So the firmware upgrade and disabling Smart Connect seems to be the solution for me.
